#1 2018-01-27 03:08:04
Shashank adkal
Fuel sender
Wanted to know the part number of smiths fuel sender fitted on austin ten Cambridge 1938..any help will be appreciated.!
#2 2018-01-27 12:37:08
6515_Peter_Christie
Re: Fuel sender
Hi Shashank,
The Austin Part Number you are looking for is probably 2H1964 [Tank Unit for Petrol Gauge] and the Gasket or Joint Washer is 2H1082.
Please note that these are Austin Part Numbers for bought in parts. The actual component was probably manufactured by Joseph Lucas or by AC Sphinx and these accessories were widely used by British vehicle builders in the '30s and '40s and may be found under Lucas or AC Part Nos. from various dealers in obsolescent car parts.
Good luck in your search.
#3 2018-01-27 16:19:26
Shashank adkal
Re: Fuel sender
Thanks for the reply Peter...this will surely help my search for the part..!
#4 2018-01-29 17:37:40
9148_kenneth_stuart_ridings
Re: Fuel sender
Try holden classic car parts they have top senders and
side ones its worth a look cheers
#5 2018-01-30 18:05:08
Shashank adkal
Re: Fuel sender
Will have a look for sure..!
   Many thanks.
