Water
Posted: Sun Oct 08, 2023 7:07 pm
by mike
Do our engine blocks have water drain taps, have searched all over but can't seem to find one. Thanks Mike. p.s 37 Cambridge
Re: Water
Posted: Mon Oct 09, 2023 11:40 am
Hi Mike,
The Austin Ten List of Spare Parts (Publication 1540, issued June 1937) shows the aluminium Water Inlet Elbow [1G418] with its threaded boss at the bottom of the curve and the Drain Tap [2H764] with its fibre washer [2K4975].
The Twelve four engine which is a similar but larger design has the coolant drain tap in a more or less similar position.
Hope this is helpful,
Re: Water
Posted: Mon Oct 09, 2023 12:49 pm
by mike
Hi Peter, thanks for that info, will look at the bottom outlet to see is it is there. Many thanks again Mike Hobson
Re: Water
Posted: Mon Oct 09, 2023 1:08 pm
by mike
Have had a look no drain tap so will flush out through top hose to give a good clean out before adding antifreeze for the winter. Thanks Mike
Re: Water
Posted: Mon Oct 09, 2023 7:55 pm
Austin Cambridge has the drain tap on the bottom tank of the radiator and NOT on the bottom water branch (BWB) like the earlier cars. But is often difficult to open. On mine I have had to drain system by removing the BWB and bottom hose, but this does not drain the last drop out of the radiator bottom tank as this is lower.
Re: Water
Posted: Tue Oct 10, 2023 4:25 pm
by mike
Hi Peter, tap at the bottom of radiator could not move the small handle, but managed to get the whole tap out of the radiator, snipped off the split pin, and separated parts. Good clean up of every part,just the fine hole to drill out rest of split pin, assemble and will have working drain tap. I did have a new one if I failed. Thanks Mike
Re: Water
Posted: Tue Oct 10, 2023 4:28 pm
Mike
Well done. Fancy coming round and fixing mine?
Re: Water
Posted: Tue Oct 10, 2023 6:20 pm
by mike
If you were closer would gladly do it, the drilling went a bit off centre, but it is together and it works but a little bit stiff, may have to use emery paper to take of a little of the taper.Mike
Re: Water
Posted: Wed Oct 11, 2023 7:54 am
Use a *very* small amount of fine valve grinding paste (or Brasso), Mike and lightly lap them in. Caution advised because you're lapping tapers and its easy to overdo it, to the extent that the plug sticks through the tap body too far and then you'll have other problems (don't ask...).
Re: Water
Posted: Sun Oct 15, 2023 6:24 pm
by mike
Used 900 grade wet, and then lapped in with brasso, now works a treat,realised not to go too far. Thanks Mike.
