Goodwood crankshaft vibration damper
Posted: Tue Jan 21, 2020 7:54 am
One for the Goodwood experts among you:
My Goodwood (late 1938 build) has a one-piece [solid] crankshaft pulley instead of the expected rubber damped one, and it looks to have been on there for a considerable time. I suspect it is a contemporary Twelve item? I was wondering whether this was an official substitution, maybe because it was found late in the model run the original damper wasn't performing as intended, or whether it was simply that some previous owner fitted it because it was the only one available at that time.
The engine generally doesn't seem to be as smooth as I would've expected, given its conservative design characteristics and I do notice a discrete period of harshness through the rev range suggesting a torsional vibration issue. As far as possible, I try to avoid operating in this zone. Ignition timing is correct and engine mounts are in reasonable condition [i.e. not rock hard]
I'm not handy to a similar vehicle to do a comparison with so I'm interested in any info or feedback on this.
Or if anyone has ever sourced/fabricated a replacement damped one.
Thanks in advance
Thanks in advance
