1935 Austin 10 camshaft wanted
Posted: Wed Dec 04, 2024 1:32 pm
by hfm944t
Hi all
Does anyone have a decent camshaft for sale for a 35 10 Clifton
Re: 1935 Austin 10 camshaft wanted
Posted: Thu Dec 05, 2024 12:25 pm
Yes I can let you have a 10 camshaft. PM me your address or if that does not work email
moderator@austintendriversclub.com
BTW why do you need one? They should not wear out.
Posted: Sun Dec 22, 2024 10:30 am
by hfm944t
Good morning
Thanks for your reply. In answer to your question why? I have the engine down on this newly acquired 10 to have new white metal bearings cast and I noticed the camshaft has one or two rough spots on the journals. As the engine is now away I cant check the block so not sure what the camshaft runs in? Are they white metal shells? Any advise welcome
Rgds
Posted: Sun Dec 22, 2024 3:52 pm
The post 1936 camshafts run on white metal circular bearings. All earlier ones have no bearing so run on the machined holes in the block. I have never seen any significant wear in the block on the earlier engines. I have had difficulty fitting a later camshaft into a earlier block, needing long-winded use of sandpaper to get a reasonable fit, but that was only once.
Christmas Greetings
