Steering Box
Posted: Mon Nov 25, 2019 2:26 pm
by David Greenfield
When the centre boss tube is removed from the steering wheel should the oil leak out of the steering box
Re: Steering Box
Posted: Tue Nov 26, 2019 9:11 am
Hi David,
If you mean the stator tube to which the indicator [trafficator] switch and horn button are attached to, using a 'Fourteen' as an example, and I'm thinking a similar age 'Ten' will be similar apart from the adjustable reach facility : Yes, any steering box oil/grease will leak out as soon as you withdraw the assembly out of the felt seal in the steering box lower cover.
Hope this helps.
Re: Steering Box
Posted: Tue Nov 26, 2019 9:20 am
by David Greenfield
Thanks Rod,
