Fuel starvation???
Posted: Fri Feb 11, 2022 4:09 pm
by Jasper
Replaced gasket etc with repair kit (Zenith 26 VA Carb) Engine starts and runs with choke right out, but will not tickover or run unless choke right out. Getting despondent now. New inline fuel filter fitted...could it be too small?? Fuel in carb bowl so pump ok. Any ideas gratefully received!!
Thanks in anticipation
Re: Fuel starvation???
Posted: Fri Feb 11, 2022 4:49 pm
by richard_mallet
Jasper, send me your email address via the Private Message option and I will email a document that details the workings of the 26VA. There are 3 minute channels in the emulsion block which, if blocked will contribute to the condition you're currently experencing.
Posted: Fri Feb 11, 2022 5:34 pm
by Jasper
Hi Many thanks for your reply...I cannot find out how to pm from this site!!!
Posted: Fri Feb 11, 2022 6:10 pm
by richard_mallet
If you're a member of this forum then the option should be at the top right hand corner of the page.
If the option is not there then click on your name and select "User Control Panel."
Select "Board Preferences", under "Edit global settings" there is an option that allows users to send and receive PM's...make sure the button is selected.
Posted: Sat Feb 12, 2022 8:14 am
by Jasper
Dont have the option...robbierance75@gmail.com
Posted: Sat Feb 12, 2022 3:44 pm
by Jasper
Many thanks for your pm
