Petrol pump 10/4 1933
Post by Jasper » Sun Apr 10, 2022 8:09 am
Morning
May be a silly question, but i have fitted an electric fuel pump to Elsie and want to refurbish the mechanical glass bowl one. Can i just fit a blanking plate temporarily ???
Thank you in advance
Re: Petrol pump 10/4 1933
Post by GaryCullen » Mon Apr 11, 2022 4:44 am
Can’t think of any reason why not Jasper.
You will want to use a gasket behind the plate to “limit” oil weeping down the outside of block.
These engines seem to generate a lot of oil splash and mist. This side of the engine relies on mist being forced up into the valve chest via 3 ( or 4 ) quite small holes to lubricate the followers and tappers. The opening for the mechanical fuel pump is just below the valve chest.
Auckland
NZ
Post by Rod » Mon Apr 11, 2022 7:49 am
Agree, no reason why not. I have done it to several other makes for similar reasons (once or twice it ended up a permanent fixture).
Just use a pump mounting flange gasket as a template to cut from, I usually cut them out of a piece of scrap 1/4" aluminium plate with a jig saw, but even wood or plastic would do, there is no significant pressure behind it, just lots of oil splash.
Post by Jasper » Tue Apr 12, 2022 9:11 am
Many thanks for your help... will commence today!!!
