Grease nipple thread type
Hi all, my Austin parts list doesn’t describe the thread type for any of the spring or king pin grease nipples.
1933 Austin 10/4. Cross member chassis with cross tube.
Can anyone advise please?
I am assuming BSP … but you never know!
richard_mallet
Re: Grease nipple thread type
Hello Gary,
I believe it's 1/8th BSP
Richard
Richard
I concur, 1/8th
I concur, 1/8th
Thanks Richard and Jasper.
I found a couple on rear springs that won’t let grease through even after I removed and washed them out with petrol.
Need replacing as I think the small ball and spring inside is rusted up.
richard_mallet
That's interesting. I too have a 1933 10/4 but I don't have any grease nipples on my rear springs nor on the front either. Would that have been for export only cars I wonder?
Yes, I believe cars for the export market had spring and shackle bushes that required greasing. UK market cars had Silentbloc rubber and metal bushes.richard_mallet wrote: ↑Wed Oct 27, 2021 10:27 amThat's interesting. I too have a 1933 10/4 but I don't have any grease nipples on my rear springs nor on the front either. Would that have been for export only cars I wonder?
I do not know the source for this info, possibly sales brochures or Austin Service Journals issued to dealers.
Hi All,
You will find that almost all of the parts books show Export Spec Front & Rear springs and shackles with metal to metal shackles and spring pins. Some also have direct grease points to the spring leaves. The early ones appear to be plain bronze bushes but the later ones have screwed steel pins in threaded bronze bushes. Straight and right angle grease nipples are listed for all of them. I think there are two thread sizes, the smaller (probably 1/8" BSP) being most common.
Peter C./Peter W. yes, Austin publication 1785 (FRA Goodwood 'List of Spare parts') has a page headed "Springs With Screw type Shackle Pins for Overseas" . I don't believe I have ever seen any UK import (of any make) of this era with anything but screw type shackle pins. Not sure why the Empire missed out on the latest technology, concerns about the state of the roads perhaps. Or worries that the locals couldn't cope with the technology?
RodRod wrote: ↑Thu Oct 28, 2021 4:50 amPeter C./Peter W. yes, Austin publication 1785 (FRA Goodwood 'List of Spare parts') has a page headed "Springs With Screw type Shackle Pins for Overseas" . I don't believe I have ever seen any UK import (of any make) of this era with anything but screw type shackle pins. Not sure why the Empire missed out on the latest technology, concerns about the state of the roads perhaps. Or worries that the locals couldn't cope with the technology?![]()
State of the roads, or maybe the climate. The rubber in the silentbloc bushes may have broken down too quickly in overseas conditions. Silentblocs reduce routine maintenance tasks but are pigs to replace when they finally give up the ghost. Greasing every 500 miles may have been the better long-term option in the bundu or the outback
Further posts on this topic evolved and have been moved to Spring Shackles and Bushes at
https://www.austintendriversclub.com/fo ... 2&start=10
