Gearbox removal
Petetherod
Gearbox removal
Hi. Is it possible to remove the gearbox from an Austin 10/4 1933 without removal of the engine? Thanks
Re: Gearbox removal
Have not done it myself but according to club Technical Reprints, yes it is.
richard_mallet
Re: Gearbox removal
I've tried both ways and found removal of the engine by far the easiest.
Re: Gearbox removal
There is a knack to removing the gearbox on its own with the early cars. The technique involves removing the near-side half of the brake cross shaft, and a jiggling of the box to allow clearance of the first motion shaft. The full description is in ATDC Magazine Technical Reprints Vol 1 pages 31 & 32. It does not work so easily for cars after May '35 and chassis No G 68569 which have a carbon-thrust clutch withdrawal mechanism.
I have removed & replaced the gearbox of a '34 Ten in the street in France on holiday when the clutch centre-plate needed re-riveting to the centre spline.
Petetherod
Re: Gearbox removal
Thanks everyone. Have joined the club so can download the tech sheets.
